I have searched for existing threads about this problem
on
App version
Beta1
Android version
17
Device model
Samsung A57 - One UI 9.0
Expected behaviour
x
Current behaviour
I suddenly noted four minor changes (2 issues (ie not really bugs but maybe needs adjustment) and 2 nice & welcome features) and checking saw that a new beta had been installed. Thank you!
They are (so far):
Issues
Widget - The contents of the widget became larger, making the controls unusable.
This was easily handled by my adjusting the Screen Zoom and Font Size
Cover Images - Under “Subscriptions” 3 of my approx. 30 podcasts lost their thumbnail images, also evident in their detailed page.
This was solved by going to Settings-Downloads-Mobile Updates and turning on cover images there - even though I was on WiFi.
Features
I now notice that when I pause listening and then resume, it restarts a few seconds prior to when it had paused. This is fantastic and compliments last release’s half second rewind when a notification interrupts. Fantastic!
Under “Subscriptions” the counter of new episodes is now also shown for folders. Nice!
Your wish is my command @Fry-kun! A picture is worth a thousand words!
BeforeAdjustment - this is basically how I saw the widget after the Beta was installed - note that I have changed it a bit so you can see the buttons, in actual fact they were barely visible.
AfterAdjustment - this is how it is basically now (also slightly changed for visibility) after I played with the Display settings in Android (Display, Screen Zoom and Font Size)
Since I was taking screenshots - here’s SubscriptionsFolders - that shows the number of episodes within my local folders, a new feature.(I use currency symbols to order them)
