Antenna Pod epsiodes syncing performance issue
Hello all,
I recently installed Antenna Pod.
I was very positively impressed! The app has some really very good features.
However, there is also one thing that I don’t like so much. I subscribed to a few 100 podcasts and updating the episodes takes a very long time and also consumes a lot of traffic.
Are there any plans to improve this? Or are there any tricks or settings to solve the problem?
Many thanks!
Limit which podcasts get updated. You probably are not up to date to all of them, you can simply disable updates of certain podcasts, you can update them manually easily if you are caught up.
Thank you. It’s a possible way I didn’t thought of. I can live with it, but I hope there will be a better solution in the long run. :blush:
