AntennaPod does not respect the per podcast playback speed setting any more
App version: 3.12.0-beta3
Android version:16
Device model: Google Pixel 7a
AntennaPod shall respect the per podcast playback speed settings. (Regression)
AntennaPod does not respect the per podcast playback speed settings at all. Only the current setting is used for the following podcast.
In the podcast’s settings the playback speed item does not show the selected speed. Changing the speed using this item does not show any effect (in contrast to the old playback service).
  1. Play podcast.
  2. The following podcast will inherit the playback speed regardless the per podcast setting.
I’ve seen the post below describes the same problem.
