AntennaPod 2.0.3 (81e2be8f2), installed today from the Google play store
Android version: 9, Kernel 4.4.147+ from 15 Sept. 2020
Device model: GS110 (9.0_V18_20200915_20200915_1623)
Expected behaviour: Could download podcasts
Current behaviour: Could not download podcasts
First occurred: Today after fresh installation
The system has a SD-card, formatted as internal storage.
AntennaPod installed on the “internal storage” SD, permission for access is set (don’t know the english terms, in German Android it is SD-Karteninhalte ändern oder löschen and SK-Karteninhalte lesen)
select storage: /mnt/expand/878aeee…c6d/user/0/de.danoeh.antennapod/files
try to add an abo, get the message "Fehler E/A error (Read-only file system)
Same behaviour if I move the app to internal storage, only difference: the path is then /data/user/0/de.danoeh.antennapod/files
