First of all, thank you very much for AntennaPod. It is the best podcast app I ever tried.
Now, the problem: after some months of usage, Data storage (not cache) grows from a few MBs (~25 MB) to hundreds of MBs (~400 MB) while cache usage remains only a few MBs (~20 MB). This are statistics taken from the Android Settings → Apps → AntennaPod → Storage (using Android 7.0). I don’t have any downloaded episode at the moment.
I couldn’t find a way in AntennaPod UI to clean up data storage, although I set Image Cache Size to only 20 MiB. The only way I could free space back was to export AntennaPod database, clear the data storage in the Android Settings screen and import the database back.
I’m using AntennaPod 2.3.2 from F-Droid repositories.
Yes, I recognize that AntennaPod sometimes seems to leave media files around, without no longer knowing about them. Yet I never bothered investigating it.
Given that you seem confident there are no downloaded episodes, I would try confirming the database is of the same opinion.
Would you be able to run the following statement in sqlite?
SELECT downloaded,file_url FROM FeedMedia
WHERE downloaded != 0 OR file_url IS NOT NULL;
Perhaps also these four:
SELECT COUNT(id) FROM FeedMedia;
SELECT COUNT(id) FROM FeedMedia WHERE downloaded != 0;
SELECT COUNT(id) FROM FeedMedia WHERE file_url IS NOT NULL;
When I do that on an export I get: 46111, 19, 59 and 59. I’m guessing that only downloaded episodes should have a file_url value, and that the 40 additional entries might be files which have been leaked. But that is really only pure speculation on my part.
Unfortunately I can not investigate further because I switched phones just days ago, and none of those anomalies in my database have occurred since then.
Yes, I’m pretty sure I delete all downloaded episodes after listening to them, either by manually deleting them or trusting the auto-delete feature.
After export/reset/import I didn’t see this problem happening anymore and unfortunately I don’t have the original export file anymore. But I’ll pay attention and reply to this thread if it happens again.
