Version: 2.3.1
How I can tag podcasts ( subscriptions) in the new antenna pod version.
Best regards
Version: 2.3.1
Best regards
Hey, welcome back. You can go to a podcast, tap on the settings icon to see the Podcast settings
, then tap on Folders
There just type the folder name and tap the +
icon.
Next time you do this, taping on the input box will show already existing folders.
But I want to use these folder as an Playlist for running, that I can hear some podcasts separately from all.
If I only have a folder tree which can sort my podcasts and not more, it’s (almost) useless for me.
But don’t understand me in an wrong way I like the app I appreciate the work from all freelancer in this project.
So may these feature will be extended over time it’ll be great.
Best regards
For the moment it’s not possible to have multiple queues. So AntennaPod can’t generate a dynamic playlist based on a podcast or group / tag.
Hopefully it will be in the future but it’s a long standing issue / feature request.
You can look at it on GitHub :
https://github.com/AntennaPod/AntennaPod/issues/2648
