How to efficiently delete hundreds of episodes from the queue
No
Motorola Moto g7 power
I expect to be able to efficiently reduce my queue of downloaded and queued episodes from 600 to 250 in less than 3 minutes, with one swift motion or set of motions.
I currently have to go into each episode and chose delete and remove from queue. Then back out, return to queue and repeat.
Forever
  1. Go into queue
  2. Enter episode
  3. Press option to delete the download
  4. Press option to remove from queue
I use Bluetooth headphones if it matters. It does not.
You can do that using multi-select
