a. You don’t have to “wait for me to paste”, I just ask claude to read the feedback directly if there’s anything actionable, and do it. I have a feeling you have unbased opinions against the tool, maybe you have not tried using it yourself, but things are not that complicated, plus that is on me.
b. You can very cheaply ($0) add a tool like Qodo or Code Rabbit on Github to check the code first and only pass it on for human review after I’ve ironed out most of the kinks.
c. “Or I have to read pages and pages of AI slop plans” - I don’t see why you should, if I won’t be committing them in my PR, unless you ask me to. I too hate reading all the verbiage (which has a very good purpose, it’s called Spec Driven Design, and it was invented years before LLM coding existed), but it’s on me as the developer to go over it before I deliver you a PR because I read some Java but I speak English better, so if I can program well enough in English, the tool will be able to “compile it to Java” more accurately.
d. As for UX design - don’t understand anything about it, I do distributed cloud design, batched jobs queued for workers on queue managers, microservices, things very different from frontend, aka UI. for me “UX” means fewer clicks and a good UI design where I see just enough info at a glance but not too much (I have ADHD and hate clutter, too much data and a bad mix of colours and fonts just hurts my brain), and above all UX means as much logic as possible is hidden from the eye, behaviour is configurable, but comes with sensible defaults. All that I have in my fork.
e. You are right, I didn’t start from the UX design. I had a general good idea about it from the get-go since I used such a system once or twice before, but since it’s my fortè, I started from the backend, designed the migration to enhance the existing tables and made new tables where it made sense. I sat for a long time interviewing Claude about the existing infrastructure and class hierarchy before I directed it where to change what, or it would go rouge and duplicate work instead of reusing existing code. So I did my home work, it was not “Vibe coding” slop, it was meticulous and intentional. It was just written in English rather than Java or Kotlin or whatnot.
If you guys want, I’ll just record you a session on the current fork I have and you can get the hang of my implementation, even if I don’t speak the lingo of a UX designer, I know how to make my usage experience more convenient to operate, aka better user experience for my not very low standards.
