When adding a local folder, Antennapod displays the title tag and if that is unset, it uses the filename.
However, for local files (randomly gathered somewhere) it is quite often the case the tags are a mess. I would really appreciate an option to (just for local folders) always use the filename. I know i could clear the tags manually but that sounds like a lot of unnecessary work for files I only want to listen once and then forget about.
