Playback notification problems
App version: 2.5.1 (from F-Droid)
Android version: 11 (One UI 3.1)
Device model: Samsung A22 5G
Expected behaviour: After playback is stopped, it should be able to be resumed via the playback notification.
Persistent playback notification is turned on in the settings:
If playback is stopped and resumed after some time, a new notification will be added, while the old one remains with no way to dismiss it and not allowing interactions. This process can be repeated, each time creating a new zombie notification.
With Persistent playback notification turned off:
If playback is stopped, the notification removes the standard playback buttons, replacing them with a generic play symbol. If I try to resume it after some time, the button will not react and the podcast episode can only be resumed by opening the app and starting it from there.
First occurred: some weeks ago
  1. Stop playback
  2. Try to resume playback via the notification after a while
Environment: Changed settings are stated above.
