3.12 release notes
Ahoy! As we slowly get closer to a new release, it is time to prepare the release notes. This is the full list of changes:
List of PRs & commits in this release
Entity Merge/Committed date URL Title Author(s) Type Functionality group Related issue(s) Related label(s) Needs review replies?
pr 2025-12-27T13:15:08Z #8180 Add ‘restore from archive’ to (multi-)select menu ByteHamster 8172 Type: Feature request No
pr 2025-12-27T18:23:10Z #8187 Add share to feed multi-select menu ByteHamster No
pr 2025-12-27T22:08:31Z #8176 Restructure feed settings ByteHamster No
pr 2026-01-01T12:28:32Z #8189 Directly enter multi-select when long-pressing subscriptions ByteHamster No
commit 2026-01-01T17:32:50Z 92d7ad9 Merge branch ‘master’ into develop ByteHamster No
pr 2026-01-02T21:32:48Z #8198 Create UI Test For About Fragment Thanush19 8174 Good first issue, Type: Feature request No
pr 2026-01-06T09:31:01Z #8205 Fix stream leak Bicente44 8169 Good first issue, Type: Confirmed bug No
pr 2026-01-06T09:36:29Z #8209 Check description position in PR check ByteHamster No
pr 2026-01-07T21:45:07Z #8211 Add screenshot mode that hides cover images with unclear licenses ByteHamster No
pr 2026-01-07T21:45:32Z #8212 Clear back stack when opening from launcher shortcuts ByteHamster No
pr 2026-01-16T22:16:07Z #8226 Add support for reading ID3 TXXX comment frames ByteHamster 8219 Type: Confirmed bug No
pr 2026-01-16T22:25:58Z #8227 Clarify that new episodes action cannot be changed when autodownload is enabled ByteHamster 8224 Type: Possible bug No
pr 2026-01-16T23:14:18Z #8228 Rename ‘delete podcast’ to ‘unsubscribe’ ByteHamster No
pr 2026-01-16T23:15:50Z #8217 Validate RSS URL before closing the AddViaUrlDialog anotherHoffmann No
pr 2026-01-18T17:50:56Z #8231 Fix issue where sleep timer is marked as active after events are fired eblis 8207 Type: Confirmed bug No
pr 2026-01-19T21:19:52Z #8233 Fix multi select actions to match single select action Consto 7144, 7849 Type: Possible bug No
pr 2026-01-19T21:31:53Z #8164 Remove separator lines in lists ByteHamster No
pr 2026-01-19T21:32:47Z #8235 Fix mixing up media id and feed item id ByteHamster 8177 Type: Possible bug No
pr 2026-01-19T22:37:26Z #8236 Stop subscription selection when de-selecting last item ByteHamster No
pr 2026-01-23T22:58:27Z #8240 Use events to handle external player state ByteHamster No
pr 2026-01-25T12:36:30Z #8242 Migrate more fragments to event-based architecture instead of keeping the service bound ByteHamster No
pr 2026-01-28T18:26:27Z #8244 Simplify playback statistics tracking ByteHamster No
pr 2026-02-04T20:41:01Z #8252 Fix still linking to Transifex ByteHamster 8245 Type: Possible bug No
pr 2026-02-07T18:11:18Z #8258 Migrate AudioPlayerFragment away from constantly bound service ByteHamster No
pr 2026-02-08T14:12:33Z #8232 Playback service rewrite ByteHamster No
pr 2026-02-13T07:04:16Z #8273 Fix media session browsing ByteHamster 8272 Good first issue, Type: Confirmed bug No
pr 2026-02-14T21:06:08Z #8276 Remove Android 5 support ByteHamster No
pr 2026-02-14T23:13:54Z #8277 Show buffering state as playing ByteHamster 8259 Good first issue, Type: Feature request No
pr 2026-02-15T09:45:25Z #8279 Avoid duplicate media notification when casting ByteHamster 5728 Functionality: (Chrome)Cast, Type: Possible bug No
pr 2026-02-17T20:13:14Z #8275 Add back Chromecast support ByteHamster 8265 Good first issue, Type: Feature request No
pr 2026-02-17T21:15:25Z #8278 Re-add widget to media3 player ByteHamster 8263 Good first issue, Type: Feature request No
pr 2026-02-17T21:53:12Z #8287 Add ‘synopsis’ comment as an alternative to description to vorbis parser ByteHamster 8269 Type: Feature request No
pr 2026-02-18T07:26:39Z #8290 Enhance self-review checklist in PR template ByteHamster No
pr 2026-02-18T12:03:21Z #8286 Upgrade target API version ByteHamster No
pr 2026-02-20T17:43:06Z #8296 Remove automatic redirect to correct website language cumeowlus 8271 Good first issue, Type: Feature request No
pr 2026-02-20T18:11:46Z #8292 Fix completing the last episode in the queue keeps it active tamilore-bello 8284 Good first issue, Type: Confirmed bug No
pr 2026-02-21T13:21:51Z #8298 Fix drawer counters not shown until counter setting is changed DivyaKhunt07 8283 Type: Possible bug No
pr 2026-02-21T15:11:06Z #8297 Move video playback controls to an independent component ByteHamster 8262 Good first issue, Type: Feature request No
pr 2026-02-21T16:46:08Z #8299 Re-implement delete after playback ByteHamster 8285 Type: Feature request No
pr 2026-02-21T20:55:50Z #8300 Re-implement video player toolbar ByteHamster 8267 Good first issue, Type: Feature request No
pr 2026-02-22T18:02:03Z #8303 Add basic agent instructions ByteHamster No
pr 2026-02-22T20:29:48Z #8304 Switch to new track selection method ByteHamster 6981 Type: Feature request No
pr 2026-02-22T20:56:09Z #8305 Small ExoPlayer tweaks ByteHamster No
pr 2026-02-25T12:30:33Z #8308 Re-add skip silence setting to new playback service ByteHamster 8266 Good first issue, Type: Feature request No
pr 2026-02-26T19:17:42Z #8309 Fix headphone double-tap skip for media3 playback service Sarnyxq 8260 Excellent Contribution, Good first issue, Type: Feature request No
pr 2026-02-26T19:24:57Z #8313 Move Statistics screen from Subscriptions menu to navigation drawer amanjn38 8310 Excellent Contribution, Good first issue, Type: Feature request No
pr 2026-02-28T08:58:43Z #8315 Re-implement sleep timer for Media3PlaybackService ByteHamster Sarnyxq 8264 Good first issue, Type: Feature request No
pr 2026-03-07T15:33:05Z #8320 Remove hidden setting from search ByteHamster 8314 Good first issue, Type: Possible bug No
pr 2026-03-07T16:25:30Z #8322 Fix crash when device does not support loudness enhancer ByteHamster 8294 Type: Possible bug No
pr 2026-03-08T07:38:59Z #8321 Build media item stub on main thread and full item on background thread ByteHamster No
pr 2026-03-08T16:13:03Z #8327 Remove fyydlin and connect directly ByteHamster No
pr 2026-03-09T23:32:34Z #8329 Switch away from JitPack ByteHamster No
pr 2026-03-09T23:32:51Z #8330 Improve usability of error printer ByteHamster No
pr 2026-03-12T20:09:18Z #8335 Update readme keunes No
pr 2026-03-13T21:37:51Z #8332 Load notification covers using Glide ByteHamster Copilot No
pr 2026-03-13T22:26:52Z #8331 Add skip intro/ending support to Media3PlaybackService ByteHamster Copilot 8323 Type: Feature request No
pr 2026-03-14T08:15:08Z #8336 Add Copilot coding agent setup file ByteHamster Copilot No
pr 2026-03-15T07:44:38Z #8342 Require at least 10 non-whitespace chars in PR description ByteHamster Copilot No
pr 2026-03-15T15:07:00Z #8341 Add deprecation warning when disabling bottom navigation ByteHamster Copilot No
pr 2026-03-15T15:48:56Z #8344 Add agent instructions about PR updates ByteHamster No
pr 2026-03-15T15:50:56Z #8340 Add missing multi-select episode actions ByteHamster Copilot No
pr 2026-03-15T16:07:44Z #8339 Move favorites to a dedicated screen ByteHamster Copilot 8253 Type: Feature request No
pr 2026-03-18T20:55:12Z #8317 Add mobile data streaming confirmation to Media3PlaybackService ByteHamster amanjn38 8301 Type: Feature request No
pr 2026-03-20T07:38:32Z #8353 Set user agent in new playback service ByteHamster No
pr 2026-03-20T09:33:59Z #8354 [media3] Add volume adaptation (boost/reduction) to Media3PlaybackService ByteHamster Copilot 8324 Type: Feature request No
pr 2026-03-22T09:28:27Z #8356 Add predictive back for main activity exit ByteHamster Copilot No
pr 2026-03-22T18:39:15Z #8357 Make sure to close all streams and cursors, enable spotbugs ByteHamster No
commit 2026-03-22T18:43:30Z 5de8d4b Merge branch ‘master’ into develop ByteHamster No
pr 2026-03-28T15:51:25Z #8369 CONTRIBUTING.md - update unit test section mpollmeier No
pr 2026-03-28T16:12:33Z #8367 Run checkstyle in parallel ByteHamster No
pr 2026-03-28T19:48:25Z #8371 Lint all modules ByteHamster No
pr 2026-04-04T19:25:39Z #8366 Fix crash when opening Sleep Timer dialog due to main-thread DB access geoffreysisco 8360 Type: Possible bug No
pr 2026-04-04T20:18:27Z #7177 Add workflows to ping about play reviews keunes Area: Project issue No
pr 2026-04-07T19:09:35Z #8380 Filter out non-subscribed feeds from GPodder subscription sync dllmr 8361 Excellent Contribution, Functionality: Synchronisation, Type: Confirmed bug No
pr 2026-04-09T21:56:52Z #8363 Implement auto-rewind on resume in Media3PlaybackService ByteHamster williamlgrt 8268 Good first issue, Type: Feature request No
commit 2026-04-11T09:19:14Z 8419a77 Merge branch ‘master’ into develop ByteHamster No
pr 2026-04-12T19:49:26Z #8365 Add Android Auto “For You” recommendations with recency filter brianjcohen 8326 Excellent Contribution, Functionality: Interacting devices, Type: Feature request No
pr 2026-04-12T20:20:21Z #8389 Implement mini rewind after interruption ghjm 2739 Excellent Contribution, Type: Feature request No
pr 2026-04-12T20:29:05Z #8391 Faster media session item list loading ByteHamster No
pr 2026-04-12T21:17:33Z #8392 Show feed covers more reliably in media session callback ByteHamster No
pr 2026-04-14T21:03:49Z #8395 Fix some lint warnings and suppress the others ByteHamster No
Which I have summarised as follows (in 491 characters, line endings not included):
∙ Rewrite playback service (@ByteHamster, @Sarnyxq and others) - this fixes many playback issues, but do report any regressions!
∙ UI changes: rename “delete podcast” to “unsubscribe” (@ByteHamster); move Statistics screen to navigation (@amanjn38)
∙ Multi-select: directly enter multi-select when long-pressing subscriptions; add more actions to (multi-)select menu (@ByteHamster)
∙ Add Android Auto “For You” recommendations (@brianjcohen)
∙ Plus an assortment of bug fixes & improvements!
Ideally we would also mention dropping Android 5 support, but all of the above will certainly affect a larger share of users.
@ByteHamster, @keunes: any comments?
Nice, thanks! I think we don’t have to mention dropping Android 5 because people on Android 5 won’t see the update or release notes.
Maybe it could be nice to mention a few more people for the media 3 rewrite: Pull requests · AntennaPod/AntennaPod · GitHub While that’s maybe less relevant for users, it might help to attract contributors. Maybe we can remove the word “media3” and instead just mention rewrite?
Done! I had to limit it to contributors with at least 2 PRs to fit in the length limit.
Can’t wait to the release! :smiling_face:
Version 3.12.0-beta1 is now under review by Google
Let’s way for uncle Google decision… :smiling_face_with_tear:
Rolling out to a random 10% of the beta testers now
:roll_eyes: Not me yet. Uncle Google is very slow on that.
Beta issues - 3-12-0-beta - Bugs
Proud and happy to be helping by being a beta tester!
BESTEST
David
See Update for Beta2 3.12.0-beta - Bugs
See Update for Beta3 3.12.0-beta - Bugs
