3.3 release notes
I worked on the release notes for version 3.3 :smiley:
Full list of changes since version 3.2:
List of PRs & commits in this release
Type Merge date URL Title Author Type Functionality group
PR 2023-11-14T20:12:03Z [#6762]Be more aggressive about telling users to also search closed issues by ByteHamster · Pull Request #6762 · AntennaPod/AntennaPod · GitHub Be more aggressive about telling users to also search closed issues ByteHamster
PR 2023-11-17T21:33:17Z [#6756]Honor sort in episode list view in Android Auto by tonytamsf · Pull Request #6756 · AntennaPod/AntennaPod · GitHub Honor sort in episode list view in Android Auto tonytamsf improvement Android Auto
PR 2023-11-17T21:51:42Z [#6765]Add ScrollView to sleep timer dialog by beijingling · Pull Request #6765 · AntennaPod/AntennaPod · GitHub Add ScrollView to sleep timer dialog beijingling bugfix Sleep timer
PR 2023-11-22T19:29:59Z [#6655]Remove Iconify from FeedInfoFragment by caoilte · Pull Request #6655 · AntennaPod/AntennaPod · GitHub Remove Iconify from FeedInfoFragment caoilte Behind-the-scenes-improvement
PR 2023-11-26T10:15:14Z [#6776]De-duplicate also if episodes have different but similar media type by ByteHamster · Pull Request #6776 · AntennaPod/AntennaPod · GitHub De-duplicate also if episodes have different but similar media type ByteHamster improvement
PR 2023-11-28T18:50:49Z [#6779]Play last episode on empty search query by ASGusev · Pull Request #6779 · AntennaPod/AntennaPod · GitHub Play last episode on empty search query ASGusev bugfix Interacting devices
PR 2023-12-02T09:44:44Z [#6783]Remove audio player license by ByteHamster · Pull Request #6783 · AntennaPod/AntennaPod · GitHub Remove audio player license ByteHamster Behind-the-scenes-improvement
PR 2023-12-02T09:45:00Z [#6782]Update debug icons with new design by ByteHamster · Pull Request #6782 · AntennaPod/AntennaPod · GitHub Update debug icons with new design ByteHamster Behind-the-scenes-improvement
PR 2023-12-03T15:36:29Z [#6789]New sort dialog by ByteHamster · Pull Request #6789 · AntennaPod/AntennaPod · GitHub New sort dialog ByteHamster improvement Sort
PR 2023-12-06T20:26:50Z [#6796]Fix 'played' state on TalkBack when cover is hidden by ByteHamster · Pull Request #6796 · AntennaPod/AntennaPod · GitHub Fix ‘played’ state on TalkBack when cover is hidden ByteHamster bugfix Accessibility
PR 2023-12-13T21:40:52Z [#6803]Make it easier to migrate Echo to a new year by ByteHamster · Pull Request #6803 · AntennaPod/AntennaPod · GitHub Make it easier to migrate Echo to a new year ByteHamster Behind-the-scenes-improvement Echo
PR 2023-12-23T19:58:13Z [#6821]Update preference search library by ByteHamster · Pull Request #6821 · AntennaPod/AntennaPod · GitHub Update preference search library ByteHamster Behind-the-scenes-improvement
PR 2023-12-28T19:15:27Z [#6822]Fix Echo using wrong number of days in a year by ByteHamster · Pull Request #6822 · AntennaPod/AntennaPod · GitHub Fix Echo using wrong number of days in a year ByteHamster bugfix Echo
PR 2023-12-28T23:07:21Z [#6831]Better center number in 'new' pill by ByteHamster · Pull Request #6831 · AntennaPod/AntennaPod · GitHub Better center number in ‘new’ pill ByteHamster improvement
PR 2023-12-28T23:07:53Z [#6830]Close unresponsive tickets earlier by ByteHamster · Pull Request #6830 · AntennaPod/AntennaPod · GitHub Close unresponsive tickets earlier ByteHamster
PR 2023-12-29T16:15:21Z [#6808]Check if volume boost effect is supported on the device by matejdro · Pull Request #6808 · AntennaPod/AntennaPod · GitHub Check if volume boost effect is supported on the device matejdro bugfix
PR 2023-12-29T16:50:31Z [#6816]Show currently playing episode in Android Auto by tonytamsf · Pull Request #6816 · AntennaPod/AntennaPod · GitHub Show currently playing episode in Android Auto tonytamsf improvement Android Auto
PR 2023-12-29T18:25:40Z [#6832]Remove unnecessary autodownload code by ByteHamster · Pull Request #6832 · AntennaPod/AntennaPod · GitHub Remove unnecessary autodownload code ByteHamster Behind-the-scenes-improvement
PR 2023-12-31T10:08:31Z [#6835]Share AntennaPod subscribe link instead of RSS url by ByteHamster · Pull Request #6835 · AntennaPod/AntennaPod · GitHub Share AntennaPod subscribe link instead of RSS url ByteHamster improvement
PR 2023-12-31T10:09:12Z [#6833]If feed url was typed manually, show edit url button on error by ByteHamster · Pull Request #6833 · AntennaPod/AntennaPod · GitHub If feed url was typed manually, show edit url button on error ByteHamster improvement
PR 2023-12-31T10:32:03Z [#6825]Add reset button to episodes filter by ueen · Pull Request #6825 · AntennaPod/AntennaPod · GitHub Add reset button to episodes filter ueen improvement
PR 2024-01-01T11:40:43Z [#6838]Add scrollbar to Nextcloud login dialog by satis-fy · Pull Request #6838 · AntennaPod/AntennaPod · GitHub Add scrollbar to Nextcloud login dialog satis-fy improvement Synchronisation
PR 2024-01-02T18:21:07Z [#6843]Use localized date format by ByteHamster · Pull Request #6843 · AntennaPod/AntennaPod · GitHub Use localized date format ByteHamster improvement Date format
PR 2024-01-02T18:56:57Z [#6846]Migrate subscriptions filter dialog to DialogFragment by ueen · Pull Request #6846 · AntennaPod/AntennaPod · GitHub Migrate subscriptions filter dialog to DialogFragment ueen Behind-the-scenes-improvement
PR 2024-01-02T19:17:29Z [#6834]Move 'skip silence' checkbox to playback speed dialog by quails4Eva · Pull Request #6834 · AntennaPod/AntennaPod · GitHub Move ‘skip silence’ checkbox to playback speed dialog quails4Eva improvement
PR 2024-01-02T19:18:21Z [#6853]Update queue list when toggling 'keep sorted' by ByteHamster · Pull Request #6853 · AntennaPod/AntennaPod · GitHub Update queue list when toggling ‘keep sorted’ ByteHamster improvement Sort
PR 2024-01-03T19:32:56Z [#6842]Print duration as number of days only on Echo by ByteHamster · Pull Request #6842 · AntennaPod/AntennaPod · GitHub Print duration as number of days only on Echo ByteHamster bugfix Queue
PR 2024-01-10T22:12:31Z [#6859]Tweaks to Echo by ByteHamster · Pull Request #6859 · AntennaPod/AntennaPod · GitHub Tweaks to Echo ByteHamster improvement Echo
PR 2024-01-04T18:10:59Z [#6849]Improve toolbar in player: always show share by ueen · Pull Request #6849 · AntennaPod/AntennaPod · GitHub Improve toolbar in player: always show share ueen improvement Toolbar
PR 2024-01-20T16:31:16Z [#6850]Hide refresh from toolbar by ueen · Pull Request #6850 · AntennaPod/AntennaPod · GitHub Hide refresh from toolbar ueen improvement Toolbar
PR 2024-01-31T20:48:39Z [#6907]Remove unused test class by ByteHamster · Pull Request #6907 · AntennaPod/AntennaPod · GitHub Remove unused test class ByteHamster Behind-the-scenes-improvement
PR 2024-02-04T18:54:46Z [#6276]Add next chapter button to notification by matejdro · Pull Request #6276 · AntennaPod/AntennaPod · GitHub Add next chapter button to notification matejdro improvement Notification
PR 2024-02-04T21:10:12Z [#6906]Tweak OPML import by ByteHamster · Pull Request #6906 · AntennaPod/AntennaPod · GitHub Tweak OPML import ByteHamster improvement
PR 2024-02-16T22:50:13Z [#6922]Use proper plurals when showing number of episodes by ByteHamster · Pull Request #6922 · AntennaPod/AntennaPod · GitHub Use proper plurals when showing number of episodes ByteHamster improvement
PR 2024-02-18T18:02:34Z [#6923]Rewind when sleep timer pauses playback by mueller-ma · Pull Request #6923 · AntennaPod/AntennaPod · GitHub Rewind when sleep timer pauses playback mueller-ma improvement Sleep timer
Commit 2024-02-18T18:25:50Z [d9ebf42]Translation fixes · AntennaPod/AntennaPod@d9ebf42 · GitHub Translation fixes ByteHamster Behind-the-scenes-improvement
Commit 2024-02-18T18:28:46Z [d7572e4]Update translations · AntennaPod/AntennaPod@d7572e4 · GitHub Update translations ByteHamster Behind-the-scenes-improvement
Commit 2024-02-18T18:31:20Z [e5f564b]Update contributors · AntennaPod/AntennaPod@e5f564b · GitHub Update contributors ByteHamster Behind-the-scenes-improvement
Commit 2024-02-18T20:15:41Z [dc63386]Bump version to 3.3.0-beta1 · AntennaPod/AntennaPod@dc63386 · GitHub Bump version to 3.3.0-beta1 ByteHamster Behind-the-scenes-improvement
Commit 2024-02-18T23:00:45Z [22f36bc]Bump version to 3.3.0-beta2 · AntennaPod/AntennaPod@22f36bc · GitHub Bump version to 3.3.0-beta2 ByteHamster Behind-the-scenes-improvement
Based on this I’d suggest the following change-log:
  • Show currently playing episode and honor sort in episode list view in Android Auto (@tonytamsf)
  • Add ‘next chapter’ button to playback notification and Android Auto interface (@matejdro)
  • New sort dialog (@ByteHamster)
  • Move ‘skip silence’ checkbox to playback speed dialog (@quails4Eva)
  • Add ‘reset’ button to episodes and subscriptions filters (@ueen)
  • Always show ‘share’ button on player toolbar (@ueen)
  • Bugfix to show remaining time in queue in hours instead of days (@ByteHamster)
Let me know if it needs any updating or if you think it’s good to go.
CC @ByteHamster @keunes
Looks good. Thanks @femmdi!
I think I’d rephrase this a little, as ‘reset’ and ‘filter’ are a bit far apart, making it harder to understand. What about
Add ‘reset’ option to filter on episodes and subscriptions screens (@ueen)
Not sure if we have the space, though.
Also a tip to make it easier for @ByteHamster: instead of an actual bullet point list, use the bullet characters and spaces from the ‘instructions’ file. App stores don’t display/recognise bullet point lists (i.e. we cannot use * signs) so we need to manually add that.
Thanks for the feedback and your suggestion - here the corrected version (
we’re at 499 characters), with bullet points from the instructions file :smiley:
∙ Show currently playing episode and honor sort in episode list view in Android Auto (@tonytamsf)
∙ Add ‘next chapter’ button to playback notification and Android Auto interface (@matejdro)
∙ New sort dialog (@ByteHamster)
∙ Move ‘skip silence’ checkbox to playback speed dialog (@quails4Eva)
∙ Add ‘reset’ option to filter on episodes and subscriptions screens (@ueen)
∙ Always show ‘share’ button on player toolbar (@ueen)
∙ Bugfix to show remaining time in queue in hours instead of days (@ByteHamster)
