Adaptive refresh rate doesn't work while audio is playing (120hz to 60hz)
App version: 3.9.0 Google Play
My refresh rate will drop from 120 to 60hz when the app is paused, but while playing audio the refresh rate does not drop on any screen, apart from the app settings screen.
Drop the rate to 60hz even if audio is playing, it only needs to be higher when scrolling. It would be better on the battery to lower the refresh rate. I suspect this may be happening as the progress bar is being frequently updated? Or on certain screens the time is advancing, as on the settings screen this is not visible and it works there. It might be a simple solution to be able to hide the progress bar and time stamps, or update them in a way that doesn’t trigger the higher refresh rate? I’m not sure but other apps manage to update content on the screen without triggering a jump in refresh rate.
