Hi all, herewith my feature request:
- V3.2.0
Downloaded episodes are currently only movable per piece in the que/playlist(AFIK). Sometimes I would like to move a list/‘block’ of episodes, i.e. depending on the time I have to listen so something (i.e. for a short travel I want to listen to a single episone of podcastA, and for a longer travel an series of episodes of podcastB). Currently it is quite tedious to move al episodes of a certain show to the desired place in the playlist.
I would like to have the option to move (/manipulate) a block of episodes at once while they keep their order.
An option to create ‘episode blocks’ would make it easy to move multiple episodes at once in a playlist. I.e. by selecting multiple episodes and select ‘add to block’.
This block should then manipulatable as once. I.e. move up and down.
Great app!
Regards Chris
