Adding a global option for volume boost and filtering episodes
App version: 3.6.0 (Google Play) (state whether from Google Play/F-Droid/Custom built APK)
Problem you may be having, or feature you want: Can you please consider adding a global option for volume adaptation and filters to display episodes (such as all, played, unplayed, starred, etc.)? I subscribe to numerous podcasts, and having to make individual adjustments for each one is quite cumbersome.
Global settings are normally for everything within the app. In this case I suspect you are thinking about everything to do with each individual podcast series. Did I get that right?
Volume boost
I don’t think we’ll have global settings for the volume boost, because it’s specifically introduced to align volumes between podcasts (and if one boosts the volume of all, it defeats the purpose). What could be done, though, is adding this as an option when multi-selecting podcasts.
global filter
This has been requested before: Global Subscription Filters · Issue #6017 · AntennaPod/AntennaPod · GitHub
