Thanks for reporting. Does the widget show “No media playback” or something else? Did you try removing and re-adding the widget? Have you moved the AntennaPod app to the sd card (using a system setting – I do not mean the media download location).
Hmm. This is not a loading screen that AntennaPod displays. It must be displayed by your home screen application. Do you use an alternative home screen application?
When creating the widget, does it open a configuration window where you can set the transparency?
Hi there and thanks for your questions. I did try a second home screen and today it works without issue. I’m calling it a weird Samsung issue. I so appreciate your support!
