Antennapod reset to blank configuration after import data base!
Hello!
I just install again antennapod on my new phone and import the data base from my old phone! All import correctly but after some times, the app return to a blank configuration. I have try to reinstall and reimport datas but with the same result!
Have you got an idea about how to resolve this issue, please? :slight_smile:
My configuration infos :
Environment
Android version: 10
OS version: 4.9.186-perf+
AntennaPod version: 3.11.0
Model: H8324
Device: H8324
Product: H8324
Manufacturer: Sony
I observe that it reset after an update of the episodes.
When update finishes, the app reset.
Is it a problem of the data base backup? Or an other bug?
When I import just the subscriptions or with a blank data base I have no problems.
Have a nice day!
This likely means that there is already a problem in your backup, but it only surfaces once the database gets written to. When did you originally install AntennaPod? Eg, how old is the database across all backups? If you didn’t reset statistics, you can get ab idea of that on the statistics screen
There might be a way to repair the database backup
I’m having the same problem. I am trying to import my information to a new phone and I exported the database and imported it to the new phone and everything is blank
What AntennaPod version? When did you originally install AntennaPod? Eg, how old is the database across all backups? If you didn’t reset statistics, you can get ab idea of that on the statistics screen
The new phone is 3.11.0 version. The old phone had been an older version (not sure which one) When I tried it the first time so then I went back and updated the old phone to also be 3.11.0 and generated again. Then just to be thorough, I went and got the fdroid version instead of the Google Play version and generated it again.
