AntennaPod stops randomly every one to three minutes
<When playing a podcast, AntennaPod stops!-- READ THIS: The latest version may be different depending on your device. You can find the version in AntennaPod’s settings. →
App version: x.y.z
  1. This
  2. Then that
  3. Then this
  4. Etc.
I’d recommend changing this from a Bug Report to a Support Request since you don’t appear to have documented a bug. (If you would like to pursue it as a bug, please provide the requested information such as app version, Android version, when you started seeing this, etc.)
Whatever it was, it stopped happening two days after my report. Thanks.
I came here with the same problem. First time using AntennaPod, long time Doggcatcher user. Generally same as has been reported. Every minute or 3 it stops. Originally I was using on bluetooth but it also stops with the phone speaker. I checked the various battery and app settings to allow running in background, etc. When it stops I press the play button and it keeps going for another interval.
One more tidbit is on the car display when it stops the podcast info and progress bar disappear until I press play and they come back.
App version: 3.9.0
Android version: 14
Device model: Ulefone X31
Expected behaviour: play a podcast until I tell it to stop or it ends.
Current behaviour: stops after a minute or so of playing. I didn’t time the intervals to see if it was consistent.
First occurred: (e.g. about x days/weeks ago) Immediately on using the app. new phone, I thought I would try something new.
  1. Play podcast. (common sense with Dan carlin and darknet diaries in my case)
  2. Press play again after it stops.
  3. repeat
  4. Etc.
Environment: both speaker and bluetooth. downloaded podcasts, I haven’t tried streaming.
