I know that a lot of hard work has been done on this bug, and I appreciate it.
Unfortunately, it still occurs, for me at least.
2.4.0-beta2
8.1.0 stock Motorola rom
Moto G5 (XT1676)
If Bluetooth earphone disconnected, Antennapod pauses playback. Upon reconnection of Bluetooth, player should re-start with audio coming via Bluetooth earphone.
Upon reconnection of Bluetooth, audio comes through phone speaker instead of via Bluetooth earphone.
In late 2019. (I believe that version 1.73 was ok, however, the version after it exhibited the unwanted behaviour.)
Connect Bluetooth earphone
Play a podcast
Pause podcast
Un-pause podcast
Yes, it is odd, and I’m aware that you were testing it before release.
All I know is, in late 2019, back in version 1.73 (I think…) AntennaPod didn’t exhibit this bug. My phone hasn’t had an Android update in that time, but being version 8, it is an old version.
I’m happy to do more testing if @tonytamsf has the time to do any investigations.
I left a comment in the GitHub issue about this. Sorry to hear you are still having this problem. Could you borrow another bluetooth device test whether this is an issue with your blooth device or my code?
@tonytamsf@Roger_V If OK for you both, let’s continue the debugging process here. Then when there’s a conclusion/clear path of action it can be posted on GitHub.
Since the issue persists for you, I guess a way to find out is to connect adb and see what’s going on?
@keunes@tonytamsf Sounds good to me. I’m eager to try some debugging via ADB, but I’ll need a bit of help with the commands, as from past experience they can be rather cryptic.
