Auto delete/mark as played
2.4.0-beta2 (ec8632ab0) Google Play
No custom ROM Android 11 build RQ3A.210905.001
Pixel 4a 5g
If I mark an episode played then remove from queue it doesn’t remove the download. Shouldn’t it? This is driving me nuts. If this was mentioned before, sorry.
  1. This
  2. Then that
  3. Then this
  4. Etc.
Hi @Singlespeednut
Thanks for chipping in with a suggestion here in the AntennaPod community :slight_smile:
In fact you’re indeed not the first one to request this - long ago there’s been a similar request on GitHub (where the app is developed):
There was a discussion there but no final conclusion as it ties in to the whole auto-download & remove mechanism, which is quite complicated. The whole auto-download area now is under discussion on our forum. So it might be a while before you can expect an improvement in this area :wink:
In the meantime I’d like to suggest to check out the Episode Cleanup setting if you use auto-download. It’ll clean up episodes for you in the background.
Thanks for the quick response. Yeah it was discussed exactly what I was looking for in that link you sent. :crazy_face: Definitely something I’ll be looking forward to.
I had auto cleanup set to “finished”. I’ll try the “when not in queue”. I usually have every podcast download automatically and if it’s a topic I’m not interested I just delete the episode manually. Hopefully that change will clean it up.
Great work being done! Donation will be coming your way.
Thanks!
