"Auto Delete" Not Working When Episode Marked as Played
App version: 2.7.1 from Google Play
Android version: 12
Device model: Samsung Galaxy Note 10+ 5G
Expected behaviour: In settings > storage, I have turned on “Auto Delete” and “Delete removes from Queue”. I expect that these setting will do what the description claim and delete the episode when it is marked played, then remove it from the queue.
Current behaviour: Current behavior is that I mark an episode as played and it stays in the queue unless I manually delete it. It is not being deleted automatically, and therefore sits there with a played status in the queue list.
First occurred: I started using AntennaPod 2 days ago, and this has been happening the entire time.
  1. In settings > storage, turn on “Auto Delete” and “Delete removes from Queue”.
  2. Go to your queue
  3. Mark an episode as played.
  4. The now-played episode is not auto deleted, and therefore not removed from queue.
I appreciate anything that can be done by anyone to fix this bug.
Environment: I do use Bluetooth headphones and Android Auto, but this seems to happen whether I’m using either of these or not.
