Automatically delete old downloads
2.7.1 (d5f0ef244)
I often forget to delete episodes after listening to them and they fill up my phone. Almost all of my podcasts have ads at the end and therefore do not count as finished for the existing Auto delete feature.
Please consider an option to delete all downloads after an interval. For example: Automatically delete all downloads when they are 7 days old.
N/A
You can use “smart mark as played” to auto-delete them even if not fully played
You’re quite right; that would certainly be an alternate solution: If the “Smart mark” feature had one final option like “When played for any amount of time” so that I can listen to the first half of a podcast then move on and it will still auto-delete.
Thank you for the reply.
