Back button is not working in settings sub menu
App version: 3.11.4f (installed from Droidify)
Android version: 16 (LineageOS 23.2)
Device model: Motorola moto g84 5G
  1. Tap on main settings menu
  2. Tap on any sub menu point
  3. Tap back button in navigation bar => App should go back to the main settings menu
  3. Tap back button in navigation bar => Page stays the same, only header is changing to previous page
First occurred: since first installation
Steps to reproduce: (s. current behaviour)
Environment:
Problem only occurs with navigation mode “3-button navigation” not in “Gesture navigation”
Problem doesn’t occur when I use the back button at the top left edge in the app.
Fixed recently in Fix back button in settings not working by ByteHamster · Pull Request #8614 · AntennaPod/AntennaPod · GitHub
but had been open for almost a year in Settings menu doesn't refresh when you go back · Issue #7934 · AntennaPod/AntennaPod · GitHub
