Android 14
Device model: Pixel 4a 5g
Expected behaviour: Download podcasts when triggered by Date/Time
Current behaviour: Nothing happens
A few days ago with the 3.4.0-beta4 update
A. Set up a Profile with a Time context
B. Create a task. In the task, add an action
- Select
System
- Select
Send Intent
- Specify Package name to be
de.danoeh.antennapod
- Specify Class name to be
de.danoeh.antennapod.core.receiver.FeedUpdateReceiver
- Specify Target to be
Broadcast receiver
- You can leave the other fields blank
Same for me with 3.4.0-beta5
It’s still broken in 3.4.0 for me
@ari_tafari I am on my phone, I cannot verify the code, but I think the receiver changed class paths?
.feed.FeedUpdate.Receiver or
Use the full path in this screenshot?
What should the full path be? Could you please elaborate?
@ari_tafari can you try the following? I am just guessing though by looking at the code
de.danoeh.antennapod.net.download.service.feed.FeedUpdateReceiver
This works for me, thank you.
Documentation on this site Integration with other apps – AntennaPod should be changed
Thanks for confirming, the docs should be changed after the latest code refactoring is released.
@tonytamsf Thank you for the solution! Much appreciated.
@Fabian1 Thank you for confirming the bug.
Just to be clear, it is not a bug. With the 3.4.0 release, @ByteHamster changed the intent during the big code refactoring. I guess we can choose to keep the old intent for backward compatibility.
Would it be possible to add other intents?
The widget has this function that a quick menu opens where you can select playing speed. That would be handy as an intent.
Or opening AntennaPod and switching immediately to the currently playing episode
@Fabian1 You will have to file a GitHub issue for the intents you want and see which developer will pick it up.
