Bookmark in episodes
App version: Fdroid - 3.9.0f (1f242876d)
Problem you may be having, or feature you want: Bookmarks with a podcast
Suggested solution: Add bookmark feature
Many times I hear something interesting in a podcast and want to come back to it later, often while walking.
It would be great to have a simple bookmark feature in AntennaPod.
Proposed behavior:
  • One-tap “Add bookmark” button on the playback screen
  • Bookmark saves the current playback timestamp
  • Optional short text note (can be entered immediately or edited later)
  • Support multiple bookmarks per episode
Bookmark management:
  • A simple list view per episode showing saved timestamps and notes
  • Tap a bookmark to jump to that time
  • Ability to delete individual bookmarks
  • Bookmarks should be deleted automatically when the episode is deleted (or at least handled cleanly)
The goal is a lightweight way to mark playback spots for later listening, not a full annotation system.
I would donate if it helps raise the feature on the roadmap. :slight_smile:
