Cant enable automatic dowload finished notificatioons
App version: 2.7.1 (from F-Droid)
Android version: 11 (lineageos 18.1 [latest] on Redmi Note 8 - Info about ginkgo | LineageOS Wiki)
Device model: (see above)
Expected behavior: can enable “automatic download finished” notification in notification options
Current behavior: can’t enable “automatic download finished” notification in notification options: when enabling the notification in the first screen and exiting and returning to the screen, the option is disabled again - taping on notification on screen, opens a screen with a greyed out option to enable the notification and a message below: “(i) At your request, android is blocking this category of notifications from appearing on this device” (I already reseted the notification settings in Android, as pointed in At your request, android is blocking this category of notifications from appearing on this device - Android Community, but the behavior stills the same)
First occurred: about 4 weeks ago (when I started to use this device…)
  1. try to enable the notification for it in settings
Bump no response yet and the problem persists
bump (the same occurs in Info about klte | LineageOS Wiki )
Hi @fbobraga
Sorry to hear about this. However, on newer Android versions (like yours), the notifications are managed at system level. When you go to Settings » Notifications in AntennaPod, you are being redirected to Android.
Also the message “At your request, android is blocking…” indicates that this is Android’s doing. So I would suggest to ask this question on the Lineage forum (or whatever support tool they have) – if you haven’t already.
Issue fixed on Android 12L: maybe was an Android bug
