Changing active podcast does not change player bar
App version: 3.4.0f from F-Droid
Android version: 10
Device model: Honor View 20
Expected behaviour: When I play a podcast the play control bar appears at the bottom. When I then play a new podcast I would expect, as I think happened before, the new podcast to replace the previous one in the play control bar.
It does not which means I can only play, pause or delete the new podcast.
If I pause the new podcast and then start it again it then becomes the active podcast in the podcast play control bar.
Hope this all makes sense.
Since most recent update.
  1. This - play podcast
  2. Then that - click play on another podcast
  3. Then this - play control bar does not update
  4. Etc.
Nothing unusual
Stacktrace/Logcat:
[if available]
Could not see how to upload screenshot in opening ticket so adding to this reply.
Strange. I don’t see this in 3.4.0 from the Google Play Store. The podcast I choose to move to play or the one currently playing is always showing in the lower player control bar bottom of the screen.
