Hi All! Started using AP yesterday and really liking what I’m seeing thus far.
I noticed in the storage options under settings, the only options I get are for my phone’s internal storage - I’d like to be able to save podcasts data to my SD card to save space/memory.
Is there a way to do this, or should it be a feature request?
You should already be seeing that as an option. One reason you may not is if the SD card is not physically being seen by your phone. Can it be seen by the Files app for example?
