Connector for Podchaser API
App version: 3.9.0 (Google Play)
Problem you may be having, or feature you want: Connector for Podchaser API with BYO-key support
I really like this app but I wish there was an easier way to browse podcast charts and find new feeds. I found the following post suggesting a similar integration, but one user pointed out the fact that the free tier limitations wouldn’t be sufficient for the entire application’s needs. I see a simple workaround for this, though, where the integration is built in, but requires the user to create their own account and bring their own key to interact with the Podchaser API. I’m no developer, so I can’t speak to the feasibility of this with the current state of the project, but I think it would be a cool idea.
