Hi, I want to contribute to AntennaPod project but, I’m learning Kotlin and android development, and my question is if is necessary contribute with java only, or I can send my code in Kotlin?
Thanks.
Thanks.
Hi @Omar_Rodriguez:
Welcome to the AP developer community. I started contributing to AP in Java only.I suspect that the maintainer @ByteHamster would want to keep the code base to Java only.
If that is the case I still encourage you to contribute to AntennaPod in Java and the language of Kotlin you can probably learn through other means such as your own projects.
I have learned quite a bit by contributing to this Java project just through the maintainer’s code reviews.
Thanks @tonytamsf, I will contribute with Java while develop my own project in Kotlin.
I want to give my first contribution to OSS.
Nice day.
