Crash at startup with 3.13.0 on /e/OS
I have searched for existing threads about this problem
on
App version
3.13.0
Android version
/e/OS 4.4.2
Device model
Fairphone 6+
Expected behaviour
Application should startup when touched from home screen
Current behaviour
Application crashes immediately at startup since today’s update.
First occurred
Since today
Steps to reproduce
Tap on the app to start, it closes instantly
I managed to find the crash report ! Here is the content :
java.lang.RuntimeException: Unable to create service androidx.work.impl.background.systemjob.SystemJobService: java.lang.IllegalStateException: WorkManager needs to be initialized via a ContentProvider#onCreate() or an Application#onCreate().
	at android.app.ActivityThread.handleCreateService(ActivityThread.java:5295)
	at android.app.ActivityThread.-$$Nest$mhandleCreateService(Unknown Source:0)
	at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2597)
	at android.os.Handler.dispatchMessage(Handler.java:110)
	at android.os.Looper.loopOnce(Looper.java:248)
	at android.os.Looper.loop(Looper.java:338)
	at android.app.ActivityThread.main(ActivityThread.java:9067)
	at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:593)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:932)
Caused by: java.lang.IllegalStateException: WorkManager needs to be initialized via a ContentProvider#onCreate() or an Application#onCreate().
	at androidx.work.impl.background.systemjob.SystemJobService.onCreate(SourceFile:62)
	at android.app.ActivityThread.handleCreateService(ActivityThread.java:5282)
	... 9 more
Caused by: java.lang.IllegalStateException: WorkManager is not initialized properly.  You have explicitly disabled WorkManagerInitializer in your manifest, have not manually called WorkManager#initialize at this point, and your Application does not implement Configuration.Provider.
	at androidx.work.impl.WorkManagerImpl.getInstance$1(SourceFile:21)
	at androidx.work.impl.background.systemjob.SystemJobService.onCreate(SourceFile:8)
	... 10 more
