Crashes while Sync
Antennapod Version 2.0.3 loaded from Google Play
Android version 10 by Xiaomi
model Xiaomi Mi 9T pro
MIUI 12.0.3. Stabil 12.0.3.0. QFKEUXM
Expected behaviour: When I start WLAN-Sync manually or by scedule normally the Play-Back of the Podcast wouldn’t stop
Current behaviour: the Play-Back gets disturbed, pauses of seconds appear and in the end Antenna crashes
First occurred: weeks ago IT appeared filor the First time. (Just after Updating the OS from Android9 to Android10
  1. Play any podcast
  2. Start sync
    Problem will occure every time
Please tell me , if you need any further information
Hi and welcome to the forum.
Could you please post the report that is displayed on the “report bug” page within the app?
Environment
Android version: 10
OS version: 4.14.117-perf-g7428a5b
AntennaPod version: 2.0.3
Model: Mi 9T Pro
Device: raphael
Product: raphael_eea
Crash info
Time: 03-11-2020 13:36:38
StackTrace
java.lang.OutOfMemoryError: Failed to allocate a 56 byte allocation with 16 free bytes and 16B until OOM, target footprint 268435456, growth limit 268435456
	at android.os.MessageMonitor$MessageMonitorInfo.markFinish(MessageMonitor.java:478)
	at android.os.MessageMonitor.markFinish(MessageMonitor.java:133)
	at android.os.Looper.loop(Looper.java:242)
	at android.app.ActivityThread.main(ActivityThread.java:7560)
	at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:539)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:950)
Thanks. Did you set your “subscription order” in the sidebar to “publication date”?
Yes. I’m using German-Translation “sortiert nach Veröffentlichungsdatum” which should correspondate to “sort by publication date”
Thanks a lot
In AntennaPod 2.0 (and older), the option subscription order » by publication date causes issues if you have a big number of subscriptions.
The bug will be fixed in AntennaPod 2.1. Until the update is released, try selecting another sort option.
Thanks you very much. This workaround will help, while waiting for 2.1
Thanks
