Creating play order
I have a folder with a bunch of MP3 files that I want to be able to play in a specific order. I use version 3.5.0, which I believe is current. I use a Windows computer and transfer files to the phone.
Is there a way to cause these files to show up in the app in the order I desire?
@Tomob since you are manually uploading files I think the simplest approach will be to rename the files before adding them to the Queue. If you only have a few files you can simply add an alpha numeric character (A, B or 1, 2 etc.) to the beginning of each file. If you have quite a few files you can use a batch renaming software (PC Magazine - Batch Renaming in Windows to minimize steps.
From the Queue select additional options (the 3 dots top right of the page) and choose Sort. Sort allows by Podcast title and Episode title. One of those selections should set up the Queue the way you want it.
