Database import without replacement
App version: 3.11.2f from F-droid
Problem you may be having, or feature you want: I want to do a database import from Phone B to Phone A. However, I don’t want to lose all the watch history and subscriptions from Phone A.
Suggested solution: Make a Database Import option that trabsfers subscriptions and playing history from one device to another without completely replacing the database.
Under Settings, Backup & restore, there is an option to import a database file from another phone.
Did you want these to be merged? That’s a pretty difficult process to do correctly.
If you want a merge, might be better to explore syncing to gpodder.net or similar.
