Source of problematic file of current revision:
irrelevant
irrelevant
The datetime parser (DateUtils.parse) parses datetime strings compliant with RFC 822.
Date parsing does not work if the time zone is given by “Z”. Note that this is compliant with the date format given by RFC 822 (RFC 822: Standard for the Format of Arpa Internet Text Messages).
Possible solutions:
One solution would be to also add patterns for the other possible timezone formats.
Note that the Java documentation is misleading as it claims that “Z” (the pattern) is for RFC 822 timezones when clearly it is not.
For instance, the string “Fri, 27 Dec 2024 13:52:59 Z” can be parsed by the pattern “EEE, dd MMM yyyy HH:mm:ss X”.
irrelevant
- Call
DateUtils.parse("Fri, 27 Dec 2024 13:52:59 Z") - See that it fails.
Stacktrace/Logcat:
[if available]
