This may have been said before, but it would be cool to be able to delete files from within AntennaPod. (From folders you added like a podcast.) Currently I have to remember the file names and do it in my file explorer. Maybe even a ‘delete all listened to files’ button.
You can delete downloaded files by:
- Long tapping on them and selecting Delete, basically from any screen where you see episodes
- Navigating to Downloads > Completed and using the Delete icon
- Automatically, using the Storage > Auto Delete option
From a UI point of view, it would be interesting to know why none of these seems to work for you.
I think this is about local folders, not normal subscriptions. Local folders currently don’t support deletion
Ah, that makes more sense! We have this covered at #5603. @Taylor.eOS, you can follow that ticket for updates.
Thanks to all responders! Yes, I was talking about local folders. (My description “from folders you added” probably wasn’t clear enough. By “folders”, I meant local folders on your phones disk.)
While I see that this has been suggested (and I didn’t follow the proper procedures for searching before making a feature request, sorry I’m new), I didn’t see any response why it isn’t possible or whether there is some technical reason why it can’t be.
Thanks.
