Disable background on notification widget
App version: 3.5.0f (f-droid)
Android 14 / OneUI 16 (Samsung)
Option to disable background on media playback widget as it hurts readability/visibility
OK, after some more digging in I think I found that it was just removed:
It’s kinda sad that the setting was removed - I don’t even have a car and don’t care about Android Auto so not being able to remove the background from the media notification is highly inconvenient.
While I understand motivation to simplify the settings to make the app easier maybe hiding some settings behind some mechanism (see “developer mode” after tapping on version) and disclaimer “if you change any of those settings don’t complain”) would be a way?
