App version: 3.5.0f (300baf6dd) (from F-Droid)
Android version: Android 15, kernel 5.10.214
Device model: Pixel 7
Expected behaviour: ‘time played’ should match total duration since I have marked all episodes as listened and have enabled the setting to “Include duration of episodes that are just marked as played”
Current behaviour: ‘time played’ does not match total duration, being hundreds of hours different
First occurred: it’s been like this since I started using the app. I only now decided to look for a solution.
- enable the setting to ‘Include duration of episodes that are just marked as played’
- check statistics to see total time listed.
- Mark some episodes as listened
- check the statistics page again… for me there is no change in ‘listed time’
additional information
attached two images
image one: of the page showing the episodes completed and discrepancy in played vs total setting enabled and
image two: the setting enabled that I think should fix this.
let me know if there’s anything I’m missing on how to fix this, or even if there’s a way to just add the hours to the total manually. it’s my most listened podcast and I’d like it to show in the stats. thanks.
