Episode Tab Smart Sort
When I’m selecting EPs to put in Que I select the top episodes in the Episodes tab sorted shortest to longest, I do it this way so I can get threw all the short eps first but also so they are semi mixed through out. Tho the problem is I get all the trailers first and some of my podcasts are overall shorter then my others so having them sorted this way makes it so I don’t get a good mix of channels so I scroll through the message tab to get more of a variety. My other option of date is okay, but it doesn’t have the good variety that sort gives.
My suggestion is to add smart sort into the episode tab. this way I can have it by date oldest to newest and it’ll still organize all of my podcasts so I can just take off the top several and I’ll have a nice mix.
I have nothing to go into this section, though one correction for a smart sort that I would suggest is on the Que tab to always put the partially played at the top. This would include the current playing EP, also, I think they should be organized from most played to least played, and then after all of the currently playing episodes, it goes into normal smart search.
