App version: 3.3.2 (Google Play)
Android version: 14
Device model: Pixel 6A
If an episode has a play symbol
I expect that it is playable.
I think maybe when downloads fail then still get added to Queue but are not downloaded. They get a
but when you hit that, you get a “file not found” toast and it changes to a download icon.
First occurred: Many months ago.
I just found a way to reproduce it
- Export your DB including a Queue from another device
- Import it into this device
Everything in the Queue will look playable when actually it’s not.
This issue probably doesn’t happen often enough to justify a fix. While I understand it seems like a bug, the audio files were not transferred.
What I do in your scenario is to multi-select all my episodes in the queue, delete, and redownload. (Make sure to turn off the remove from queue when delete option)
Maybe on importing a database AntennaPod could ask if you want to download episodes that are marked downloaded. If user say no then I agree their downloaded state should be reset. (Or simply always reset downloaded state ?)
I understand it can be minor but as AntennaPod offer to import a saved database I think it should be considered.
