Error Downloading podcasts
App version 2.7.1 (d5f0ef244)
Android 13 - New Pixel 6A
Pixel 6A
Podcast downloading.
Downloads should be in the /Android/data/ed/danoeh.antennapod/files folder. There is nothing there.
The player reverts to streaming of the podcast.
exported the configuration from a Samsung S21 and imported it to the Pixel phone.
  1. This
  2. Then that
  3. Then this
  4. Etc.
Auto downloaded enabled.
Did you check if in settings, playback and playback control section you didn’t have “prefer streaming” turned on?
Hi, thank you everyone. I found the Download when not charging was turned on, and with a 12 hour check for downloads, that meant it would download during the night, ( when on charge) I turned this off and changed the time to 4 hours and all fixed!
