Failing to refresh feeds - No network connection?
App version: 3.4.1f (8c2d641ba) from F Droid.
Android version: 10 ( eOS used.1.17.1)
Device model: Samsung SM-G930F
Expected behaviour: Refresh Feeds
Current behaviour: Get a popup notifcation at bottom of screen saying No network connection, individual feeds show last refresh failed red banner.Tap to view detials shows:
IO error Failed to connect to XXX URL.
(Internet connection and connection to individual feeds is possible through other means, only antennapod is having a problem).
First occurred: about 4 days ago. I was downloading a number of podcasts when one failed (was connected to VPN at the time), then since that failure, this error won’t go away, tried rebooting device.
  1. Try to refresh feeds manually by swiping down/up in inbox
Environment: Not sure if applicable. No proxy set up. No VPN connection etc.Mobile data is all allowed. No automatic download
Stacktrace/Logcat:
[if available]
After reinstalling AntennaPod and reimporting the database, this solved the issue. Does anyone know of a way of exporting your settings too?
There is no way to export your settings, but my guess would be that resetting your settings actually was what solved the issue.
