Would like to know how much data will be used by downloading vs streaming an episode
Add filesizes next to stream and download buttons, or alternately to the confirmation box for downloading over mobile as this is when people will generally mind large files.
I think this one’s pretty self explanatory so in this space I will say thank you again to the devs for making the best podcast app!
If you have your podcasts set to stream, instead of download, the file size is listed above each episode in feed right next to the upload date. Just set podcasts to stream in settings.
Some RSS feeds have a glitch causing size/length to not show until you play it, but it’s very rare & usually only happens on certain RSS feeds converted from a website. That bug, in my experience, isn’t on AntennaPod’s end and often resolves on its own.
There’s no way to gauge how much cell/WiFi data a download or stream will use beforehand. Knowing the file size is more than enough, and doesn’t matter if you’re streaming. Just clear app cache regularly if tight on storage space.
EDIT: Check your feed update interval settings. The less often it refreshes feeds for new episodes, the less background data & battery will be used. Set it to largest interval & only update on WiFi.
