GOOGLE PLAY
ANDROID 7
LG REBEL 3 SMARTPHONE
BUG REPORT LISTS 3/18/24
NO UNUSUAL BEHAVIOR OTHER THAN COVER ART BEING REPLACED
WUTH GRAYED BOX WUTH PODCAST NAME
AFTER DEVICE IS AWAENED AFTER USING
SLEEP TIMER
FIR PLAYBACK.
Environment
Android version: 7.0
OS version: 3.10.49-g01e0dc6
AntennaPod version: 3.2.0
Model: LGL158VL
Device: lv1
Product: lv1_trf_us_vzw
Crash info
Time: 18-03-2024 00:13:30
StackTrace
java.lang.NullPointerException: Attempt to invoke virtual method 'void android.support.v4.media.session.MediaSessionCompat.setQueue(java.util.List)' on a null object reference
at de.danoeh.antennapod.core.service.playback.PlaybackService.lambda$loadQueueForMediaSession$1(PlaybackService.java:350)
at de.danoeh.antennapod.core.service.playback.PlaybackService.$r8$lambda$3kCEWuNcq1SHYOtaxSddkU4SmrY(PlaybackService.java:0)
at de.danoeh.antennapod.core.service.playback.PlaybackService$$ExternalSyntheticLambda13.accept(R8$$SyntheticClass:0)
at io.reactivex.internal.observers.ConsumerSingleObserver.onSuccess(ConsumerSingleObserver.java:62)
at io.reactivex.internal.operators.single.SingleObserveOn$ObserveOnSingleObserver.run(SingleObserveOn.java:81)
at io.reactivex.android.schedulers.HandlerScheduler$ScheduledRunnable.run(HandlerScheduler.java:124)
at android.os.Handler.handleCallback(Handler.java:751)
at android.os.Handler.dispatchMessage(Handler.java:95)
at android.os.Looper.loop(Looper.java:154)
at android.app.ActivityThread.main(ActivityThread.java:6315)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:872)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:762)
- This
- Then that
- Then this
- Etc.
Stacktrace/Logcat:
[if available]
