Suggested solution: I suggest adding to the shutdown timer the ability to turn off the player after completing the playback of a particular podcast. For example: you listen to a release, turn on the timer to turn off after the release is completed and go to bed, and you will be sure that the player will turn off automatically after the release ends.
If you are speaking about setting sleep timer to stop after current episode (or any number) then it will be available in 3.11.0.
