AntennaPod version: 3.2.0 (58081fe5b)
Android version: 11
Device model: Blu G91S
Expected behaviour: When I set the global playback speed in the app settings, I do not expect it to change every time I change the playback speed on a specific podcast.
Current behaviour: Changing the playback speed in the settings for a particular podcast results in the app’s global playback speed setting to be changed to the speed set in the podcast.
First occurred: this behavior always occurs.
- Set the global speed to 90% and close settings.
- Select any podcast and open it.
- In the settings for the podcast, set the playback speed to 100%. Then close the podcast.
- Close and reopen the podcast and confirm that the playback speed is set to 100%.
- Open the app settings again and confirm that the global playback speed has been changed to 100%.
Environment: no changes were made to the environment.
Stacktrace/Logcat:
[if available]
