App version : 2.0.3 Google Play
Android version : 10.0
Device model : Oneplus 7
Expected behaviour : Episodes that previously where played should be marked as played after synchronization
Current behaviour : Episodes that previously where played not marked as played after synchronization
Steps to reproduce :
Install AntennaPod
Import a few podcast subscription via importing OPML
Enable synchronization via login to gpodder.net
Mark some episodes as played
Start Force sync to synchronize
Uninstall AntennaPod
Enable synchronization via login to gpodder.net and selecting an existing device that you created at step 3.
Wait for podcasts to synchronize
Hi! Did you come across this post? It explains gpodder and some of its settings in more detail.
For synchronization, AntennaPod uses the free service gpodder.net . In order to synchronize your clients, you need to create an account there.
After you created the account, I suggest to create a device on gpodder.net/devices/ for each client that you use:
[image]
After you created the devices, link them using the “Configure” button. This way, gpodder.net automatically keeps the subscriptions of both devices synchronized.
[image]
Then, have a look at AntennaPod’s Settings » Integration…
Yep, I have seen that post but still, it is confusing for me.
I tried to use also second Linux client and it didn’t work for me I guess because I haven’t created a device before login in at the second client.
I’m not talking about 2 devices in this case but about just 1 that gets readded after reinstallation and selecting an already existing device.
In my humble opinion, in such a case, it should sync already played episodes, but it doesn’t as far as I see.
Does the gpodder website show that the episodes are played? You can check that on the “Episode history” page:
Yes, it is checked as played. Here is one example.
