I know where to find, but its greyed out. Nothing to choose
Android version: newest
Device model:fairphone 4
really? No answers? No solution?
Missed your initial post. The only options for this I have to choose are a specified folder on the internal storage and a specified folder on my SD card. This suggest you cannot choose your own folder and that if you do not have an SD card then internal storage is your only option so that is why it is greyed out for you.
thanks!
I have to try that with the SD Card, on my old phone, I also have had it on a SD Card…
With my favorite player (Simple ABP free) I can’t access to the actual folder
