How to save export to cloud storage on phone?
App version: 3.5.Of
Android version: 16 - but using GrapheneOS
Device model: Pixel 6a
When I attempt to export my data from the app, whether OPML export, database export, or HTML export, the only place it allows me save this is in Pixel 6a files. When I go to the Files section, I can see all the exports that I’ve saved there.
What I am wanting to do is place a copy of this export file into cloud storage, so that if something happens to my phone, I will be able to retain all my subscriptions. I have a Tresorit (cloud storage) folder on my phone. But I don’t see any way to save these exported files to that location.
Maybe this is a GrapheneOS issue, but thought I would ask here.
Any suggestions appreciated! thanks !
Search around. There are Android apps such as DriveSync and FolderSync that can keep one or more mobile folders sync’d up with some/most clouds, especially Google Drive.
I just wanted to come back and report that I solved this issue - once I got the correct type of cable (usb-a to usb-c), I can connect the phone to my laptop and see the exports from AntennaPod on the pixel. I can transfer these to my cloud storage from there. Hope this helps someone else who might be having the same issue.
