Implement Android 13 per-app language setting
App version: 2.6.2 Play Store
Problem you may be having, or feature you want: I want to switch the language of the app to one other than the default, now it’s easier for the developer with Android 13.
Suggested solution: Per-app language preferences  |  Android Developers here are a few ways to implement it.
Now also on GitHub: Option to change app language · Issue #7117 · AntennaPod/AntennaPod · GitHub
